February 24, 201214 yr ...at least I think it's a relationship problem but I could be wrong. Please refer to the attached. (Account Name and Password: test) If you go to the Business-Grouped Contacts or Personal--Grouped Contacts tab, you'll see a radio button value list that, when clicked, should show records that share the same name, company, city or state. Try as I might I just can't get it to work and I suspect I may have the relationship wrong but I don't know. (I can be thick sometimes.) I'm sure it's one little thing that I overlooked, so if you can tell me I'd appreciate it. Thanks! CL Customers.fp7.zip
February 24, 201214 yr Try as I might I just can't get it to work Perhaps it does work, but you don't have any data that would show it does? --- BTW, I would appreciate it if you posted files that do NOT require me to log in manually. Edited February 24, 201214 yr by comment
