March 3, 201214 yr Newbies Hi All A few days ago i've discovered ScriptMaster. It seems that it is what i was looking for. I followed the tutorial but there is still one error comming again and again. Unfornunately after clicking for generating Plugin ("Make Plugin") an error is apearing: "com.prosc.license.client.InvalidLicenseException: Error registering 360Works ScriptMaster: You must purchase an Advanced Edition or Portfolio License to use this feature." I created already a plugin. Moved the Database to another Directory and now its not working anymore. Does somebody know what to do?? I have no glue where the problem could be. I'm using ScriptMaster for personal use and there should not be any restrictions!!!! Thanks in advance B
March 3, 201214 yr Register the plugin on opening the file. Check the folders where your generated plugin was saved for a file called Registration.txt.
