Layout problem in OS X 10.1
I have installed OS X 10.1 and have found that some of the layouts in my FM Pro 5.5 database are not displaying.
Screen comes up blank, but if you click in various areas, the fields in those areas will appear.
This is a simple, basic layout never had any problems in Mac OS versions all the way up through OSX 10.0.4
Anyone else seeing a similar problem with 10.1?
Bruce
I am having this problem too. It goes away after quitting FMP and relaunching it. It does not happen often but is scary when it does.
  • 2 weeks later...
Because some aspects of FMP 5.5 are supposedly not available in OS X, I chose to install the OS 9.x version and run it in Classic mode. It works fine there...youmay want to do the same.
