FMPro 5 and 4.1 on same machine
Can you run both Filemaker Pro 5.0 Unlimited and 4.1 on the same machine. They don't need to be running at the sametime but I would like to work with both versions on my Powerbook.
Tom Beidler
Orbit Tech Services
tbeidler@mindsprin
g.com
quote:
I have all recent versions of FMP running on my Powerbook, with no preceptable problems.
Kurt Knippel
Senior Filemaker Developer
http://www.database-resources.com
mailto:[email protected]
  • 3 weeks later...
It is fine to have them on the same machine and run them at the same time. Have them set up to different web companion port numbers (if you are doing anything with web companion) and if you are networking use a dif appletalk for one and tcp/ip for the other.
Beltro
