Running count problem in a portal
Greets, all:
I have a quick question; please refer to the first of two attached screen shots.
When the portal auto-creates a new record it automatically populates the Balance column's field with the Start Quantity value (from the upper-right corner); is there a way to prevent that from happening?
It could be the way I have the calculation defined; please refer to the other attachment. Would coding the calc differently solve the problem?
TIA for your help!
Rich
post-76798-0-72550200-1339596280_thumb.p
post-76798-0-17235800-1339596749_thumb.p
I can only assume from your first screenshot that you want the balance value displayed only if a value for WithdrawnReplaced has been entered.
If so, then
If ( not isEmpty ( WithdrawnReplaced_lxs ) ; StartingBalance_lxn + WithdrawnReplaced_lxs )
should do the trick.
Worked like a charm. Thanks!
