"Aborted by User" / "Invalid Command" Running a System-Level Script on FTS12
Hello, I'm fairly new to this forum and to FMS in general but I've been working on the Training Series the past couple days and I've recently stumbled on a problem I'm unable to fix.
After creating this simple system-level script to run on schedule (for cold backup) I am getting an error that states aborted by user and/or invalid command. My suspicion was that it had to with my system since I had an error opening FTS 12 several times and I had to reinstall it, but I am receiving the same error when I attempted to run it on PC (I'm currently working on a Mac).
I believe that FTS is having trouble finding/locating the script which is causing this error. I've spent many hours troubleshooting this trying to find a solution but have had no luck.
Suggestions?
Thank you in advance,
Stanley
Here's my script:
#!/bin/sh
fmsadmin send -m “Pausing” -u schoi -p Password123!
fmsadmin pause -u schoi -p Password123!
fmsadmin backup -u schoi -p Password123!
fmsadmin resume -u schoi -p Password123!
fmsadmin send -m “The backup is complete. Files are again open for use” -u schoi -p Password123!
What are the privileges on the script file in Mac OS X?
That's a unix shell script. It won't work in Windows.
I removed the "#!/bin/sh" should that not of made a difference for Windows?
The settings were all correct, I checked time and time again that the privileges were given full the custom access. Using iRepair, I gave the Owner, Group, and Others full access with "Exec." in addition to setting it 777 under fmserver / fmsadmin.
