Remote Scripter problems
Hello, I am having a problem with the 360 Works Remote Scripter plugin. I have the plugin installed under /applications/filemaker/extensions and it works fine while just using Filemaker normally. However, when I go to IWP and open the database with my browser I get a plugin not installed and nothing works (I am using the remote scripter demo so I know its not faulty scripts) Is this because I am trying to run the plugin and IWP all from one copy of FileMaker? Any help is appreciated. Oh and I am Using Filemaker 11 pro advanced and running OSX.
Our plugins do not work with IWP in FileMaker Pro. This implementation would need to use IWP in conjunction with FileMaker Server to use the plugin. In such a case, the plugin has a specific directory it should be installed into. Instructions for plugin installation can be found here.
Well that explains my problem then. Thank you.
