looking for 4 FM Pro licences between v8.5 and v11
There really isnt a proper place on the forum for this request, but i will put it here for now. Admins, feel free to move it.
I am assisting a local shop with a software upgrade and i have found that whoever set up their initial system used a single version of FM6 and a keygen to set up the initial database. The new software they are installing requires FileMaker v8.5+ to be installed in order to work. The shop does not have much to spend since this is an unexpected expense. Does anyone have some old, unused licenses that they would be willing to sell? The versions do not need to be the same, but must be between v8.5 and 11.
Thanks!
-Chad
Automatic message
This topic has been moved from "FileMaker Legacy Versions 7 – 9" to "Member Lounge".
Be careful buying a licenses off line, as most of them have been used for upgrades and are not eligible for resale. I think FileMaker Inc. will check a license for eligibility if you provide a number.
