Newbie need help to display images and pdf in IWP with supercontainer
HI
First I'm only a  Network and system admin but  a total newbie in terms of IWP , file maker and  have been assigned the following task
We have the following setup. FIlemaker  Server 12 Adv running a DB with IWP
I have external users accessing the DB without any issue. But I need them also to see images and pdf in the DB
I'm running the java applet version of supercontainer for the time being and once everything works we will purchase the full version
I did  go through the docs but its quite confusing for me :sad:
In my sample DB, im inserting a web viewer and then defining  a custom web address ex http://localhost.local:8020/SuperContainer/Files/my/path/logo.jpg. Its works even there is a frame around the picture but when I do same for the pdf  http://localhost.local:8020/SuperContainer/Files/my/path/a.pdf.  Both the pdf and jpg are located in same folder
 its just display the error http status 404
I would be grateful if someone could guide or advise me, on a better way to get this to work
The plan is to have a folder on the local server in ex e:Pdf and have all pdf stored there and then user supercontainer to link to them
cheers
Fred
Hi Fred,
SuperContainer hosts files in a "one file per folder" structure. The reason is so that SuperContainer doesn't deal with the name of the file but rather the directory where the file sits. So your custom address should not contain the filename, but rather a path to the folder that contains only the file you want. If there is more than one file in a folder path, SuperContainer will only return the first file that it finds.
However, I don't get a 404 error when trying to access another file in a folder holding two files. Rather I just get the first file that SuperContainer finds (usually alphabetical order). Your getting a 404 error may be related to a different issue.
Unfortunately, because of the way SuperContainer handles files, you will not be able to store all PDFs in a folder and link to them with SuperContainer. They must be in a "one file per folder" structure for SuperContainer to function properly.
