Display Dialog Boxes in same Monitor
If I open a Filemaker database in a second monitor, the dialog boxes pop up on the first monitor.   Is there a way to keep Filemaker open in the second monitor but have the dialog boxes open in the second monitor as well?
Hmm. I believe if you move the dialog box once it's open it will appear where you left it. I could be out to lunch on this though.
  • 3 weeks later...
Each dialog box can be moved over to the desired monitor.  But can't seem to make them appear in desired monitor to begin with.
