February 13, 201412 yr I just created both 32-bit and 64-bit versions of the same plug-in using ScriptMaster and was surprised to see that the registration string was different. Is there any reason for this? Just curious.
March 10, 201412 yr I have also had this issue, which is a bit frustrating. Reported to 360, but did not get a reply…..however, I have not gotten to push them again for an answer…. Furthermore, I experienced today, that the 64 bit version would not install under Windows7 64-bit…. It basically crashed FM13…. Should the plugin file be renamed ? How can you, with autoupdate function, determinate whether the OS is running 32 bit or 64 bit ?
March 10, 201412 yr Just talked with 360…. Regarding the 64bit, well, the 64bit version of the plugin is for using on server only…... Maybe that is the reason that you get 2 different registration strings…?? and maybe they never thought it would be an issue…?
