Popover as data entry Help
Hello Everyone,
Just registered to the forum and this is my first post and very new to Filemaker. I was watching a video on the youtube about popover as data entry by Martha Zink, but theres no sample file on that video so what I did while watching Im also taking note the scripts steps she used, but as Im implementing its been a challenge to me because I cant make it work. Any help that you can extend is highly appreciated.
Please find attached sample file.
Please also move my post if I posted it on the wrong section of the forum.
Thank you so much.
Popover.zip
Welcome to FMForums!
Well, Newbee, for being new to this forum, you're doing very well.
Your global fields are not set (in Options > Storage) as global.  Small change and it should work fine.  :-)
Thanks Laretta,,,,your suggestion works like a charm!
