Help on URL Scheme for iLinea FMG using iFinea Tab 2 credit card scanner
In talking to a rep there at 360 works it was recommended that I use a scanner from infinite peripherals.  We bought the ifinea tab 2 credit card scanner, but I am surprised that  it came with no instructions on how to make it work with FMP Go.  We had to order one that was coded for FMP Go, but nothing to help out making it work.
I have done research and figured out what I need to do, but I am stuck on the URL Scheme.  I believe I have to use the app 'iLinea FMG' for this process.
I started another topic in the iPad area.
http://fmforums.com/forum/topic/92342-url-scheme-for-ilinea-fmg-app-using-ifinea-tab-2-credit-card-scanner/
Scott
In case others have this same issue, I was able to get this to work.  The people from Infinite Peripherals helped me out.  Here is the URL Scheme:  "iLinea://" & Get ( FileName ) & "?script=" & Get ( ScriptName ) & "&param=none"
Hope this helps others.
Scott
  • 3 months later...
Hi Scott
Could you elaborate on this a bit? We have just got ours and also have no docs to work from! Crazy really...
My app iLinea FMG just crashes so I can't even edit the settings...
Have you had luck using this system?
Steven
  • 2 years later...
I have it working, although the device seems to detach itself quite often and can't be found.   When speaking with the folks at ipcmobile to order your device, be sure to tell them you want one compatible with FMG.  Here are the docs:
iLinea FMG.pdf
Edited by MichaelStevens
