PDFs and Word Documents not opening with Go, is my script right?
The script I use to open PDF and Word documents on a Mac and PC does not seem to work on the ipad or iphone.  It simply says it cannot find the container.
They are externally stored with the secured setting.
Is there a better mechanism for this?
Presently I have:
   Set Variable [$path; Value:Get (Temporary Path)]
    Set Variable [#filename; Value:Middle (GetAsText(Authorities::authorities_pdf) ; Position (GetAsText(Authorities::authorities_pdf): "/" ; 1 ; PatternCount (GetAsText(Authorities::authorities_pdf); "/")) +1 ; 1000...]
    Set Variable [$final_path; Value:$path & $filename]
    Export Field Contents [Authorities:authorities_pdf; "$final_path"; Automatically open]
Now, the above does work when I connect with a PC or mac, but seems to fail on Go.  What am I doing wrong?  Perhaps everything!
