Fonts not there and DOT printer Problem
Hello
I have FM5.5 running on Win NT4 SP6, I want to print on a DOT printer using
the Courrier Font (printer not TTF),It print faster
#1 what is the best way to have it all aline, so it's not printing using
graphic mode ( I know how to do it in Crystal Report, but not in FM) is
repeating fields row standard distance is the correct way :
#2 I can select in Add more fonts, the standard Courrier (Non TrueTypeFont)
on one station and by I don't know what "gizmo" I have now in my list of
fonts Courrier 10cpi, Courrier 8cpi... the same font is install on other
station and I can't get those to appear... only "Courrier".... and when I
edit Layout in the other station.... I mess-up the old layout cause the font
is not the same size....
I have check.. it's not the fonction "Only display TTF in application" and
NO there's no other file name Courrier 10 etc etc
I have the same version, the same file in the "Fonts" folder it's only FM
that does'nt but it in my list......
I Why FM is not WYSWYG when I ZOOM 200%-400%, and aline my fields, they are
not aline on printout or 100% view :
Or do you have another solution too print on DOT printer, another working
font ??
I'm also using Repeating fields, 2 Portals and Merge Texte in the same page
(Page 1 of 1 only)
