Making Body Invisisible
I was wondering if it was possible to have the Body of a layout invisible.  I would like to have a toggle to have it visible and not visible.  Do I have to make 2 layouts?  Or can I have a toggle that will make if invisible (even if sorting is needed to do that, like with leading summaries).
Thanks you in advance,
Fed
Leave away the body part; instead, add a sub-summary part that is sorted by primary key. This will act as a faux body part.
Use a sort order that ex- or includes the primary key field to hide or show that part.
Thanks, that worked perfectly.
