DataTables Deep Dive - Replacing Portals - Part 1
Portals and list views represent one of the biggest reasons for using a database for managing data. You can view the data in a myriad of ways and FileMaker provides the tools to modify the views quite easily.
FileMaker's list view happens to be the most powerful when compared to portals. We don't really have the same feature set presented within a portal. Using a portal it's an all or nothing approach to sorting by default and you can't really search the portal contents. You can certainly hack in some method of controlling the sort and the old standby of simply adding new copies of the same portal, just sorted in different directions, has always been a go-to workaround.
Well, has the time come to simply abandon your portals? What?!?!! Abandon portals? Is that even possible in FileMaker?
Actually, it is, with what FileMaker now offers with bi-directional support within Web Viewers, it may be more viable than you've ever considered. In this two part video series I show you exactly how easy it is to simply retrieve some data, then present that data within a web viewer. Essentially, replicating a portal - except for the constant data connection.
In many ways, this has become a prime opportunity to choose either a portal or web viewer. The days of always using a portal may have come to an end. But, I'll let the video speak for itself and you can choose if you want to leave your portals behind in favor of what can now be done within a web viewer.
View the full article
