Using Color Effectively
When incorporating graphic design into your FileMaker solution, you might either be the sole designer or collaborate with someone to enhance the user experience. Regardless of your role, it's always beneficial to understand how to effectively use colors within your solution.
You can, obviously, make straightforward choices, such as simple selections of colors from the built-in color picker. But, there are additional tips and techniques that can significantly enhance your ability to use colors strategically, helping you achieve your ultimate design goals.
Whatever your objectives may be, understanding the best practices for selecting, applying, and implementing colors in your FileMaker solution is essential.
View the full article
