Web Viewer in Web Direct with "No Applet" has no buttons
FM 13, SuperContainer 2.9
Web Viewer in Web Direct on iOS ( iPad ) using "No Applet" shows the image,  but has no buttons to "delete" or "Upload"
What am I missing ?
greg
Edited by gdurniak
  • 2 weeks later...
This issue was resolved via our support system. For anyone coming across a similar issue the problem was an outdated SuperContainer web app. If you are seeing a similar issue be sure to check that you are using the most up to date version and update as necessary. You can test to see what version of SuperContainer you are using by going to HOSTNAMEORIPADDRESS/SuperContainer in a browser.
  • 2 months later...
I'm using:
360Works SuperContainer 2.93, build 8277 (9/17/15)
I have the same issue?
21 hours ago, The Crow said:
I'm using:
Is your SuperContainer server accessible externally? Could you provide the URL and the style parameters you are using with the web viewer that doesn't show create/delete buttons?
If you'd like you can send that information to [email protected] if you don't want to post them here. Thanks!
I did a uninstall and re-install and now it works...
