Array Building - Key Number Problems
Hi All,
Apologize if an answer exists already...did some research to no avail.
I have a script running a 2D array on a single table of records which has worked fine for me in past projects, but this time the "key" is a simple number field as opposed to a text field.
The problem is that the numbers range from 1 up over 2000.  The Array seems to lump some of the single, double and triple digit numbers into the 4 digit number keys also affecting the totals.  Basically, as a result instead of 1744 records being reported the array is lumping everything into only 818 records despite the "key" being unique and records with 4 digits are reporting inflated totals.
The reason for this array function is to future proof the table when multiples of keys are added (and serve other queries)
Fields in question are as follows:
EVENTS::__fk SHOW ID# (I've tried it as a Text and Number Field also validating)
Here's the array function (the rest of script works fine):
Let (
localArray = $$Rainbow ; key = EVENTS::__fk SHOW ID# ;
pos = Position ( localArray ; key; 1 ; 1 ) ;
rowNum = ValueCount ( Left ( localArray ; pos ) ) ;
rowData = Substitute ( GetValue ( localArray ; rowNum ) ; "|" ; "¶" ) ;
PrevGrandTotal_Proposal = GetValue ( rowData ; 2 ) + 0 ;
PrevGrandTotal_COGS = GetValue ( rowData ; 3 ) + 0 ;
PrevSalesTax = GetValue ( rowData ; 4 ) + 0 ;
PrevLabor_COGS_Estimated = GetValue ( rowData ; 5 ) + 0 ;
PrevSupport_COGS_Estimated = GetValue ( rowData ; 6 ) + 0 ;
PrevLabor_Actual = GetValue ( rowData ; 7 ) + 0 ;
PrevCOGS_fromQB = GetValue ( rowData ; 8 ) + 0 ;
NewGrandTotal_Proposal = Case ( not IsEmpty ( EVENTS::ws_grandtotal_proposal_n ) ; EVENTS::ws_grandtotal_proposal_n ; 0 ) + PrevGrandTotal_Proposal ;
NewGrandTotal_COGS = Case ( not IsEmpty ( EVENTS::ws_grandtotal_cogs_n ) ; EVENTS::ws_grandtotal_cogs_n ; 0 ) + PrevGrandTotal_COGS ;
NewSalesTax = Case ( not IsEmpty ( EVENTS::ws_nys_salestax_proposal_n ) ; EVENTS::ws_nys_salestax_proposal_n ; 0 ) + PrevSalesTax ;
NewLabor_COGS_Estimated = Case ( not IsEmpty ( EVENTS::labor_cogs_total_n ) ; EVENTS::labor_cogs_total_n ; 0 ) + PrevLabor_COGS_Estimated ;
NewSupport_COGS_Estimated = Case ( not IsEmpty ( EVENTS::labor_support_total_n ) ; EVENTS::labor_support_total_n ; 0 ) + PrevSupport_COGS_Estimated ;
NewLabor_Actual = Case ( not IsEmpty ( EVENTS::actuals_labor_n ) ; EVENTS::actuals_labor_n ; 0 )   ;
NewCOGS_fromQB = Case ( not IsEmpty ( EVENTS::actuals_COGSfromQB_n ) ; EVENTS::actuals_COGSfromQB_n ; 0 ) ;
newRow = key & "|" & NewGrandTotal_Proposal & "|" & NewGrandTotal_COGS & "|" & NewSalesTax & "|" & NewLabor_COGS_Estimated & "|" & NewSupport_COGS_Estimated & "|" & NewLabor_Actual & "|" & NewCOGS_fromQB & "¶" ] ;
Case ( pos = 0 ;
localArray & newRow ;
LeftValues ( localArray ; rowNum - 1 ) & newRow & RightValues ( localArray ; ValueCount ( localArray ) - rowNum ) ) )
Any advice is greatly appreciated...hope I've explained it well enough.
Well, sleeping on it I found the culprit on my own.  Here's the fix if anybody has similar problems.
Changed the line
 TO
pos = Position ( localArray ; key; 1 ; -1 ) ;
so now it searches the array properly.
