February 26, 20197 yr Hello I have a solution in which I use many functions requiring 360SM plugin. I'm under a virtualmachine Windows 10 through Parallels Desktop 14. I installed my FileMaker Advanced 14 and the last 5.1 of Scriptmaster. The plugin is activated (Preferences/plugins) When I open my fmp12 file I get a message saying it requires version 4.02 of SM minimum What can I do ? Thanks and regards ! Noël
February 27, 20197 yr Hi Noël, I am not sure that this error message is coming from ScriptMaster. I searched the entire ScriptMaster code base for any occurrences of "4.02" and the only occurrence was in the change log. Also, our error message windows have a heading of "360Works + pluginName + Error". That is hard coded so I do not believe it would change regardless of locale. Does the solution have a start up script that does a version check by chance?
February 28, 20197 yr Author Hello ! You're right ! I looked and found a script testing the version. After disabling that line everything runs fine. But I thought the syntax was correct : look where is the error Cas ( $_SMVersion = "?" ; "\"ScriptMaster plug-in\" n'est pas installé sur cette machine..." ; ObtenirNombre ( Substituer ( SMVersion ; "." ; "" ) ) < 402 ; "La solution nécessite \"ScriptMaster plug-in\" version 4.02 minimum." ; "" ) Noël
