How to clear a check box, after script has ran?
I have a script to email a list of selected items, which works great!  But the check boxes stay checked after I run the query, how do I clear them??  With my other fields I simply do a  Set field [inventory::Email_Info ; "" ] and it clears out the data, that doesn't appear to work with my checkbox field.   This must be a simple fix to clear out all checks, but I can't figure it out, please help 😉
THANKS!!!!
Is Email_Info a global field? If not, setting it to "" will only clear it in current record. If you want to clear it in all records of the current found set, you will need to use the Replace Field Contents script step.
Note that marking individual records is not good practice. It adds an unnecessary modification of the record, and of course will fail in a multi-user scenario with one user overriding the selection of another. To select multiple records, add their IDs to a global field or a variable.
It is not a global field.  I could easily do that and make it a global field it that will work.  There will be less than records in the inventory field.  So it is not a big database.
When I make it a global field all of the records in that database become checked at once, so I DO NOT want global field.
So how do I just clear all the records from being selected?  I don't want to have to manually uncheck them each time.
As I said, by using  Replace Field Contents script step.
I am afraid you're missing the point. The idea is to add (or remove) the clicked record's ID to a list held in the global field (or variable). The user does not see the contents of this list. They only see a checkmark that's hidden or shown based on the presence of the record's ID in the list.
Sorry but I am not understanding what you are saying, I am still new to FM.
I have a query that takes all records that have been checked and then writes them to a PDF file which is then emailed out, which is awesome :-)!
Then I simply need to uncheck the checked records, how is this not some simple line in a script?
