February 10, 20215 yr One of our clients asked for how to create payment QR-Codes in FileMaker and we just made him a new example for this. You may prepare the data, but then you can use MBS Plugin to create the barcode and put it as picture in a container and print it on your invoice. Or you use DynaPDF to draw it as vector graphics to keep it sharp. Here is the main script with the full calculation to assemble the text for the barcode: # EPC-QR-Code generation # Go to Layout [ “Tabelle” ; Animation: None ] # Sample data for QR-Code. May need adjustment to final standard Set Variable [ $text ; Value: // Service Tag "BCD" & ¶ & // Version (001 oder 002) Right( Tabelle::Version ; 4 ) & ¶ & // Character set: 1 = UTF-8 "1" & ¶ & // Identification: SEPA Credit Transfer "SCT" & ¶ & // BIC of receiver. optional for EEA Tabelle::BIC & ¶ & // Name of receiver Left(Tabelle::Name; 70) & ¶ & // IBAN of receiver Tabelle::IBAN & ¶ & // Amount. We replace comma with dot for German amounts "EUR" & Substitute(Tabelle::Amount; ","; ".") & ¶ & // Zweck, 4 letter code, optional Left(Tabelle::Intention; 4) & ¶ & // Reference 35-Character-Code, see ISO 11649 RF Creditor Reference Left(Tabelle::Reference1; 35) & ¶ & // Reference Left(Tabelle::Reference2; 140) & ¶ & // Note to user Tabelle::Note ] # # Barcode options. We use high level as we draw over barcode. Set Variable [ $o ; Value: MBS("Barcode.SetOptions"; 4) // ECC Level with values from 1 = low, 2 = middle, 3 = better, 4 high. ] Set Field [ Tabelle::Code ; TextFormatRemove ( $text ) ] # # CRLF line endings needed Set Variable [ $text ; Value: MBS( "Text.ReplaceNewline"; $text; 3 ) ] # We render barcode at 4x size for better drawing later Set Variable [ $img ; Value: MBS("Barcode.Generate";"QRCODE"; $text; 0; 0; 0; 4; 0; 1; "UTF-8") ] If [ MBS("IsError") = 0 ] # Save to field Set Field [ Tabelle::Barcode ; MBS( "GMImage.WriteToPNGContainer"; $img; "barcode.png" ) ] # # Clean up Set Variable [ $r ; Value: MBS( "GMImage.Destroy"; $img) ] End If Feel free to try the example database with next plugin pre-release and let us know if you find some issue. If we have changes to the script, we'll keep the example database updated for you. Please do not hesitate to contact us with your questions.
