Subsummary report with multi-column body section
Howdy, howdy:
I'm curious if there's a cheat where FMP will create reports where the sub-summary sections can run the width of a page but the Body section would print in columns; it would make some of my reports much more visually pleasing.
TIA for your help,
Rich
This may do the trick depending on your desired output.
No cheat is necessary for this; you just need to select "Across first" as the columns direction.
Thank you both.
It's a personal preference thing, though: I'm/we're used to seeing people's names in ascending order vertically, not horizontally (when using "Across First"); it's a little like visual ping pong.
It's times like these where I wish FMP was more robust when it comes to document formatting. *wistful sigh*
Then you will need to reorder your records accordingly. I think that's what Stephen's file does (haven't examined it).
