Problem with upgrading from Mirrorsync 4 to Mirrorsync 6
I started the process by doing an initial sync on a device using the current installation of Mirrorsync 4.
I then installed Mirrorsync 6 and configured it.
I returned to my device and tried to sync.
I first got an error about insufficient privileges which I fixed by adding the api privilege to the sync privilege set.
Now I get an error 104
Configuration: xxxHub: xxx.direct / xxx (FileMaker Server)
Spoke(s): Demouser IPHONE( username 'demouser', running Go_appSDK 1.524 on xxx.xxx.xxx.xx, ping time: 67 ms, machine name: 'iPhone' )
Error when attempting to execute script on FileMaker database: xxx.direct / xxx (FileMaker Server); An error 104 occurred.
It's supposed to sync using Mirrorsync 4 scripts since the app has not been updated but it can't seem to find them for a mysterious reason.
Edited by sfpx
Error 104 is missing script. It sounds like you may need to edit the configuration in MirrorSync 6 and make sure that all of the steps have been followed there.
Do you have a script in your solution, executable by your syncing user, named 'MirrorSync 6 (mydb)' ?
Also, do you have a script named 'MirrorSync 6 worker' ?
Yes
It was required to edit the name of the script in the first step of ms 6 configuration
It should be executable by my syncing user since I edited his privilege set to run all executable scripts
Attached is the privilege set of the user
I changed it on the server but not on the device (could it be the problem ?)
It should be changed on both the server file and the offline copy, although the error you've posted is specific to the server file.
Do you also have a script named 'MirrorSync 6 worker' on the server?
Those scripts are on the server
The redacted part is the name of the database as it appears in the log
Also, I was asked to insert the url in the script that I was asked to rename.
This screen is no longer there when I edit the configuration
If guess that it means that it's configured correctly.
Edited by sfpx
Any idea on what to check or to send you ?
I'm currently stuck with no idea what to do.
All I can think of to do is see if I can reproduce the problem. Could you send me an empty clone of the database, with admin credentials, and I'll see if I can reproduce the problem? Email to [email protected]. Also file a problem report using the MirrorSync launch page, this will send me your log file and an export of the configuration.
I already filed the problem (ticket 126311)
I will check if I can send you a file shortly
I tested an initial sync.
If I use the mirrorsync 4 script I will get an error 104
If I use the mirrorsync 6 script it works (I get a schema changed warning at the beginning though).
Initial sync with ms6 seems slower than ms 4.
Took 15 minutes while my ms 4 initial sync this morning took 3 minutes (unusually fast though)
P.S.
I noticed an error in the config import.
I have a table that uses 2 primary keys...only the second one was imported in the ms6 config.
