Problem with looping script
I have a script called "generate 100 records" in a FM 13 table called qrgen that is supposed to run another script called "new record" which creates a new record then generates a QR code using the Google API. The script is supposed to run for 100 iterations but it doesn't stop at 100.
I found this FM 12 example which I would assume should work in FM 13 (the first example): https://fmhelp.filemaker.com/help/12/fmp/en/html/create_script.13.32.html
Here's my script:
Loop
    perform script ["new record"]
   set field [qrgen::counter; qrgen::counter+1]
   Exit loop if[qrgen::counter>100]
End loop
I cannot figure out why the loop continues past 100. Any ideas would be appreciated.
PS: I've posted a version of the file here if you'd like to see it: www.blue-iceberg.com/files/qrcode.fmp12
Edited by rcacciato
Why not attach the file here, it's much more convenient.
From what I see, the counter field is not a global field - so instead of being increased at each iteration, each record gets a value of 1.
I am also puzzled why you're not using a variable as the counter instead of a field. The example you refer to seems very ancient. Note also that you're not following it correctly: if you want to use a field as the counter, then the field (which must be a global field) needs to be reset to 0 (or empty) at the beginning or at the end. Yet another reason to use a script variable (prefixed by a single $) which expires when the script has run out.
Ah, right. Thanks for revealing the mystery... let's say it's been a long time. I didn't know about script variables--I learned FM a century ago. How does one use a script variable? I changed counter to a global field and it worked. Then I made another change and now it doesn't... Argh.
Attaching the file here as you suggest.
Thanks so much!
qrcode.fmp12
OK scratch that, I got the counter to work.
But I don't know about script variables. How does one use a script variable?
Thanks.
Try it this way:
Go to Layout [ “qrgen” (qrgen) ]
Loop
  Set Variable [ $i; Value:$i + 1 ]
  Exit Loop If [ $i > 100 ]
  Perform Script [ “new record” ]
End Loop
Wow. Simple and elegant. Thanks for explaining this, you've been a huge help!
