Validate using IsEmpty or Less than/Greater than
I am using FileMaker 5.5 on a Mac
If the field "Total Material" is empty or less than 1 (this is a calculation number field)
I should to be able to enter a number in field "Other Total" (this is a number field)
If the field "Total Material" is NOT empty or is greater than 1 (this is a calculation number field)
I should NOT be able to enter a number in field "Other Total" (this is a number field)
Attach a script to the Other Total field:
If(IsEmpty(Total Material) or Total Material < 1)
Go to Field (Other Total)
else
Go to Field ()
Make sure you take Other Material out of the tab order.
As an alternative, you could use this calculation as a validation calculation for "Other Total".
-bd
