A little problem about Unique key ?
Hi All
File A , 2 fields , Field A1 = 12 Field A2 = nil so unique key= 12nil
so first time I go from File A to File B ..I create a record in File and set unique key of File B = 12nil
Second time I change Field A1= 12 Field A2 = 123 so uniquekey = 12123
So How can I go From File A to File B which don't create new record in File B but go to the same record of File B (12nil) and change unique key of File B = 12123.
Somebody can help me with this since I tried many ways but no idea how to implement that ...since I know that one unique key to one unique can not change like that?
I really need your help
Thanks All
Start with the following premise: Keys NEVER change, keys are NOT accessible or ever seen by the user and user/system modifiable values are NOT keys.
So create a unique key to link the records and establish a relationship via this field. Then you can use this relationship to modify those other identifiers as they change.
I suggest looking into the following thread for my implementation of a unique key system, which is the primary linking system for the relationships, and can be used when other user-defined linking systems (such as CustomerID, or InvoiceNumber, etc) need to be modified.
CaptKurt's Unique Key System
Thanks Capkurt,
you make my day...
That is what i am thinking but could not figure out how to make primary key.
Once again
But if I duplicate it gives me the same primary ...how can we avoid it?
I want that when it is duplicate it gives different primary ...
Any idea?
I control all record creation and duplication through scripting and I do not allow user access to the menu for record creation. So they cannot choose Duplicate Record or press Command-D. They must press a "Duplicate" button on the layout. This then allows me to assign a new PrimaryID to the duplicated record, as well as whatever other functions need to happen upon duplication.
When I duplicate I got a new primary key ...do you know how to get a duplicate of related file with the new primary key when I duplicate the original file.
To duplicate a set of related records, you'll need to do some scripting.
Basically I do the following:
Store Original PrimaryID (i.e. CustomerID_pkey)
Duplicate Record, Assign New PrimaryID, Store New PrimaryID
Goto Related Records by Original PrimaryID
Loop Through Related Records, Duplicate Record, Set the ForeignKey (i.e. CustomerID_fkey) to the New PrimaryID. Also make sure to Assign a new PrimaryID (i.e. InvoiceID_pkey) to the duplicated record.
Eventually you will have duplicated all related records and set thier ForeignKey to the new PrimaryID.
Thanks Capkurt ...
I got your idea ...
Once more ...thanks ...because that problem gives me headache
