Problem with Find Script - Posted for Techy
I was trying to post for help on this problem.
I am trying to find/omit records over multiple fields.
I have a Postcode Field (Main DB)(set as a valuelist checkbox) this works fine on it's own.
I have a Members Field (Relational DB) again works fine on it's own.
I have a County Field (Main DB) again works fine on it's own.
I need to find AND/OR Omit Records that match ALL 3 Fields?:
My Current Script is.....
show all records
enter find mode[pause]
set field["membership:membership"]
omit record(depending on what the user enters)
new record/request
set field ["county"]
omit record (depending on what the user enters)
new record/request
goto field["postcode"]
set field["postcode","not isEmpty(postcode & "
test post
  • 2 weeks later...
Hmmm... how about have a calculated field that is a concatenation of the three fields you search on.
Then set up 4 global fields. The first three getting populated by the you're above script SetFields. Then 4th global being a calculation field defined like the previous one to do the concatentation. Then omit all records where the global field matches the non global concat field.
