Problems with a portal
Hi all,
I have a portal that brings up records from a second database thru a relationship, and it works fine. I get all records from 2nd DB where status="live". But now I want it to use one more criteria for the selection of the records shown. I also want to match ClientID between the two DBs.
So I want to show all records from 2nd DB with status="live" and ClientID=ClientID.
Is it possible? How do I do?
Martin
In your related database, create a calc field (result of text)
Status & ":" & Client ID
In your main file you have two global text fields.
1 for status (gStatus) and 1 for client id (gClientID)
Now you have a calculation (result of text) that is
gStatus & ":" & gClientID
Your portal uses these two calcs for its relationship
HTH
