strange problem...
Hi
I have a link in my page.
the code is : "http://fmp:591/FMPro?-db=web_reservation_form.fp5&-format=testres_form_change.htm&-lay=web&reservation_id=[fmp-field:view_reservations::reservation_id]&-find"
and for some strange reason the "reservation_id=[fmp-field:view_reservations::reservation_id]" part is displayed exactly as it shows in the code, that means that FMP skipd this part and will not show the content of =[fmp-field:view_reservations::reservation_id]
What could be the problem ?? (the field is on the web layout...]
Ok, I found the problem :
I am using dreamweaver, and when editing a link through it's GUI windows then instead of character like "/,[,]" it is using their htm code for example "/=%5c"
What you have to do is manualy insert the link.
tnx
All the best.
Garry
