Problem with Timbuktu
I have a problem using Timbuktu Pro to connect to a FileMaker database when I try to connect with a computer using Windows. The computer I connect to uses Mac OS9 and filemaker 5.5. When I start FileMaker on the remote computer Timbuktu shuts down because of an unexpected error. It is strange because It works great working with all software on the remote computer except for FileMaker. I have tried using both Windows ME and XP, but i still cant use FileMaker on the remote computer. Has anyone else experienced the same problem?
//Greger
This is a known issue with Filemaker and Timbuktu and has existed for a couple of years now. I do not recall every trying it with Filemaker 6. We went back and forth with Netopia quite a bit to try and get it resolved, but basically it is nothing that they can do, it is something that Filemaker was doing with the display.
Will it work if both computers use windows? Or is it impossible to work with FileMaker with Timbuktu on Windows?
On Windows use free VNC or Terminal Services, which is the best technology from Microsoft.
We did not have a Windows to Windows testbed to work with so I do not know.
Our boss was using TS on Mac X since September 2002. I believe without problem.
