September 17, 200322 yr Hello Everyone...I'm having trouble printing when I use this script. It will only print the first 5 records out of 40 plus records. Can anyone help me out please. Thank you. Go To Layout ["Postcard"] Enter Preview Mode [] Print [No Dialog] Enter Browse Mode [] Go To Layout ["Pacific Ford"] -Raul
September 17, 200322 yr Print [No Dialog] Uncheck this box once, then run your script and set the Print box parameters to "All". Then, press continue. When over, go back to ScriptMaker and reset your [No Dialog]
September 17, 200322 yr Author I can't belive it was just that easy. I'm disapointed with myself to have overlook that. Thank you Ugo for the "Printing 101" class
September 18, 200322 yr I attach a Comment before each Print (no dialog) script step, so that I can see which were the preferences defined for the printer. This saves some time to debug.
