December 9, 200322 yr Newbies greetings all! I have little problem and I don't really know if it can be solved.... I have a computer (duh!) that is connect to 2 printers (let say and laser printer and a LABEL printer. One of my file maker document requires the Laser Print and the other the Label printer. question: Is there a way to script the change of printer without having to go into the page setup every time? I just find that everytime that I have to print out a label that I have to change the print setup or else it will print on the laser, and when I print out a label, I have to change it back to the laser.....grrrrr... HELP!! Learner
December 9, 200322 yr You can store the page setup in a FM script, but not the printer choice (unless you use a plug-in): Page Setup (restore, without dialog) ==> define the appropriate page setup right before Print (with dialog) ==> and you have "only" to change the printer manually
December 10, 200322 yr I also face this problem before, what i do is create a script a setting menu. When user want to use laser printer, they only go to chane one time an then can use for all script. If they want to change printer, then can go to change on the setting menu. But i think this is not the best way for your case if you always need to change printer. Detlev, is that the new picture is you? i think yesterday i still saw the baby picture. Regards, Henry
December 12, 200322 yr Do you see a difference, Henry? Actually, the new picture shows my father and I use it now, so that nobody can tell me I'm too young for this site
