Strange Printing Problem
I have a very strange problem that does not relate directly to any topic.
When I print a specific list view (from a script or not)if leaves out the name on the 13th entry. It prints everything else on that line - like age-grade-barcode, etc.
I tried it on another printer to verify it was not just the print driver. It is not at the top or bottom of the page. There are 21 lines on the page.
Any ideas?
Hi Rfox,
You may have an errant carriage return in that 13th record's field. Place your cursor at the end of the data and hit delete a few times then try it again. Is it always this specific record, or just always the 13th record in your list? There are other problems with printing but they would change to different records. If it stays on just this record, it's probably a CR. smile.gif
LaRetta
It was the 13th record on each page of a 7 page report.
I simply started from scratch and created the layout all over again and it is not doing it. So it must have been something ont he layout.
Thanks.
