March 2, 200422 yr Thanks everyone for the "break name into three parts" help I have a problem with the city state zip field. I'm trying to parse data from one field to three fields City State and Zip The data looks like this: Any ideas? Here is what the data is like: Lake Oswego, OR 97201 Portland, OR 97201-0000 Oregon CIty, OR 97830 Gresham, Oregon 97208-0001 West Linn, Oregon 97208-0001 Problem is Cities can be one or two words and Zip is one or two words. Any Ideas?
March 2, 200422 yr Hi Brian, OK for the City... Left( field, Position( field, "," , 1 , 1)-1) For the zip... RightWords( field, Case(Position( field, "-" , 1 , 1) = 0, 1, 2 ) ) In both these replace field with the field that contains all the text Still looking at the state, will get back to you on that! BTW, these calculations are dependnt on a comma aftr the City, and a hyphen if the zip is 2 words. Regards Ed
March 2, 200422 yr It's all in the definition, I guess.... Here's a solution that worked for all the samples you listed.... CSZ = Data in current form... City, state, zip City = Left( CSZ, Position( CSZ, "," , 1, 1)-1) TruncState= Replace( CSZ, 1, Length(City)+2, "") This is an intermediate field. State= If( Length(RightWords( TruncState, 1))=4, Replace( TruncState, Length(TruncState)-10, 11, "") , Replace( TruncState, Length(TruncState)-5, 6, "")) ZIP=If( Length(RightWords( CSZ, 1))=4, Right( CSZ, 10), Right( CSZ, 5)) My calculations were "interesting" when there was acidentally a carriage return at the end of the line in the CSZ field. Makes counting from the end a litle more tricky. Paul Parsing City State Zip.pdf
