Web Sharing Problems
I have gone through the routine to publish Filemaker on the web with mixed results. Some people get on some don't. On one friend's computer, I am able to log onto the file on the his local computer using either http://LAN-IP:port or http://WAN-IP:port. On mine, this doesn't work. It says it can't find the server, though it finds the server fine when I use port 80. (I am using port 8081 for Filemaker). One friend is able to log onto my published Filemaker and also onto his locally published filemaker, while when I try to log onto his Filemaker remotely, his Filemaker goes into spinning disk mode and he has to force quit the software. This latter seems to mean that I am knocking on the door, but things are getting hung up somehow.
Any ideas? I hate these inconsistent results. It doesn't leave much to hang onto.
Are there any particular ports Filemaker likes or dislikes? I can log onto my own computer using this syntax http://LAN-IP:80 and when I try http://LAN-IP:8081 I get a server not found error. I've tried other ports with similar errors. My router is set up correctly to forward the right ports.
Any Windows/MacIntosh issues I should know about?
--Kenoli
Version: v5.x
Platform: Mac OS X Panther
It seems Safari 1.2 is the culprit. Se related post.
--Kenoli
