Help me please!! Picture into Container????
I have to solve this today. How do I put a JPG into a container field??
I created a simple database... number, first name, last name, and picture (a container field).
All fields are on a layout... viewed as a list... I've entered a few records... all the data went in just fine... the container fields are all blank.
Now, I want to put a small JPG into the container field. The JPG is sitting on my Desktop right now. I tried dragging it and dropping it on the container. Nope. I tried right clicking on the container, selecting Insert Picture..., and then in the dialog selecting the JPG file. Can't, the JPG file is grayed out... even though I am allowing All Documents. I tried using the Insert menu's Picture... command... same problem in its dialog.
I checked the Field Format for the container field... it does allow entry. I checked the Options on the container field under Define Fields... nothing is checked... so modification is allowed.
What am I doing wrong?? Thanks for any suggestions.
FileMaker Version: 5
Platform: Mac OS X Jaguar
how about Edit--Preferneces--Document--[]Store Compatible graphics?
try embeding it and then inserting it with relative path...make sure that image is tryly .jpg not just named file.jpg
...strange...
post some more after the tests
Take care!
Yes, I've tried all the commands that I mentioned with "Store Compatible Graphics" set both ways.
And I've also tried just saving a link rather than the graphics.
And yes, its definitely a .JPG... the tiny view even appears on the desktop... so Finder sees it as a JPEG and has no problem shrinking it and displaying it.
Any other ideas?
Something seems to be wrong. I guess you knew that. If it's not too big, why don't you post the .jpg here and others can see if it works for them. Perhaps it's a "progressive" jpg? Does FileMaker support those (I don't know)?
I've tried different JPEGs, don't think its that.
How about this... here's the database!
Its a trivial little thing... please tell me if you can get a pic
to go into the container in Competitors. Thanks!!
Scoreboard.zip
Works for me. Inserted a jpeg into Competitors. It showed up in the other files. Why don't you attach one of you jpegs, or try some from another source.
I see now that you're using v.5. Do you have the last version update for that? The first 5.0 was a little buggy.
Hi, kennedy!
I inserted 3 JPG files, 1 showed up perfectly, 1 was not visible at all, and 1 was distorted. I think there was a problem rendering the re-resolutions to make them fit. Maybe check to make sure the JPG is the proper size/resolution for your field. I know you needed this yesterday, but if you're still working on it, it may be worth a go. Also, you might have been able to do a quick COPY/PASTE.
(used OS X FMP 6)
--ST
Hmmm... is this just a bug in v5.5? Can anyone make this work with 5.5?
Perhaps its time to upgrade to v7...
Well, I have no problem at all, either with Copy/Paste or Insert command with Jpg, gif, Qt...with both 5.5v1 and 6...
FileMaker Version: 6
Platform: Mac OS 9
I've had this happen before and have always been able to solve the problem by opening the file in Photoshop and resaving. However I can't tell you want settings I was using at the time. Post or email me an example file, I'll convert it and return to you with the settings.
