Problem with serial numbers
I am having a problem with auto-entering serial numbers into a Packing List file.
What i want to do is for every packing list number have the item number field start generating from "1".
i.e.
Packing List # 398335
have the item numbers start generating from one and continue in increments of one.
then when I create a new packing list number....let's say 398337, I want to have the item number field revert back to generating numbers from one.
I hope that my explanation is clear.
Thanks.
Make a self-relationship, packing list number::packing list number, let's call it packlist.
Then either by script or auto-enter calc, set the item number to Max(packlist::item number) + 1
Thanks Tom! That seemed to work.
  • 2 weeks later...
I have a nearly identical requirement, and I tried this technique. I would prefer to create the related records (i.e. those which would contain the "restarting" sequence numbers) by entering data into a portal. It only seems to work when the max(myfield) expression is reevaluated, and this is not predictable. Sometimes it works and sometimes it doesn't. Any thoughts?
