TextStyleAdd Problem
I can't seem to get the TextStyleAdd function to recognize styles when referenced from a text field, placing the style directly in the function works fine, but referencing a field produces no change.
Am I missing something?
Here's the Calc I'm using basically taken from the example in Help:
TextStyleAdd ( TextStyleAdd ( FormatText::Txt1 ; Plain ) ; FormatText::FontStyle)
Where FormatText::FontStyle is a text field.
The styles are not text strings, they are numbers, the calculation is interpreting them as named constants.
If you play around with it a little, you'll notice:
Plain = 0
SmallCaps = 2
TitleCase = 48
Bold = 256
Italic = 512
etc.
So, when the help example states:
TextStyleAdd( titleField; SmallCaps + TitleCase )
you could instead use:
TextStyleAdd( titleField; 2 + 48 )
as well.
You could make your calculation work the way you'd like by changing it to:
TextStyleAdd ( TextStyleAdd ( FormatText::Txt1 ; Plain ) ; Evaluate( FormatText::FontStyle) )
and Evaluate() will determine the correct style-number from the name given.
Shadow, thx for the clarification.
Rod
