HELP! How Can I Write My Own Script?
AGH! THIS IS FRUSTRATING!!!
I'm using Filemaker 6 on OS9.2.2, and I enter in my script name, hit create, and it comes up with the script definition window. This is where I'm having trouble. I want to MAKE my own definition, type it in manually. I've looked EVERYWHERE! How can I do this? This this something that's driving me CRAZY! HELP!
Hi
You can [color:"red"]not type directly into the Script Step Box (box on the right side) in FileMaker, you have to select them from the list on the left.
Is there a plug in program that can alow me to do this?
Phew! Glad I got that out of my system.
AGH!
This sucks....
But alas...I feel the need to use the bananas as well...
Hi Final Print,
If you are on a Mac and using system 9.x and below, you might check out a utility
called AutoScript.fm Pro By: Gregory Charles Rivers URL:
http://www.fmfiles.com/dev12.html
Hi Queue,
Those are bananas, I that they were dancing Hot dogs.
: grin.giftongue.gifgrin.giflaugh.gif
Yes, they are bananas...I hope...
I am trying the program you posted as we type...
I sent you a private messages here.
