June 12, 200421 yr I have a fields with a sum of different values (e.g: FieldGTotal=field A+field B, where Field A,B,etc equals regular numbers. In one field I have a pop-up menu which gives me the option to choose the measurement unit used to calculate to Field B. : each, inches and yards. This is what I am trying to do:::::::::::::::::::::::::::::: FieldGTotal= Sum of all Fields if i chose "PCS" the calculation for the "FieldGTotal"="field A"+""field B"*1 (Field B= countable product ) if i chose "Inches" the calculation for the "FieldGTotal"="fieldA"+"field B"/36 (Field B= measurerable product)(result given in Yards) For Example Field A! Field B! Unit Measured Field! Gtotal Field 500 !72 !inches ! 1000 100 !5 !PCS ! 115 Do I have to make a separate database to put inches values and etc? What is the best solution for this? Please help.....
June 14, 200421 yr Hi, ronnie! I'm not familiar with your terminology, but I think what you have would work using an IF statement or a CASE statement. I always find syntax a chore but it'd be something like... FieldGTotal = if (field B = "PCS", field A + field B, field A + (field B / 36)) or case (field B = "PCS", field A + field B, field B = "Inches", field A + (field B/36), 0) Anyway, the point is you can change the formula/equation depending upon the value of field B. Alternatively, you can create another field called "B converted" that would convert B to a base unit and then you could re-adjust the total to the appropriate unit from the field B selection. I many not be understanding your question correctly, though... but I hope this helps. --ST
June 14, 200421 yr Author Dear Steve T., Sorry about my terminology. thanks for the help... I see the the solution now... thanks for the help... that script should do the job .
