Web Search Problem
Hi Everyone,
I have a problem when I try to do something on the web search for FileMaker. The customer wants to have "2 search textboxes" on one particular field. However, when i try to use "-Lop = OR" in the HTML, it seems comes up with the search of all the "OR" results for that HTML page fields.
I just wondering if someone can give me any idea or solution for this problem. Thx a lot if you can help me.
Cheers,
Jas
Unfortunately, you cannot mix Logical Operators (-lop), nor can you apply them to particular fields.
A way aroud it is to use [FMP-If] tags in the Format file. You may have to assign values to Tokens.
Good Luck.
Garry
Hi, Jas!
Of course, it's not very elegant and I'm not sure how particular your client is, but you could just have two forms and 2 submit buttons. This would not work for an AND situation, but since you were looking at OR anyway... it may be good enough. The client may not care that there are 2 submits... he/she may just want to make sure there are two boxes to search by. You could reduce the clutter and noticibility (word?) by using small GO graphics instead of submit buttons, too. (The web visitor would actually have to click on the submits, though, since there would be 2 forms and I think pressing RETURN would only work on one form.)
--ST
Hi Guys,
It's me again.
I am thinking if it is possible to submit two find requests to the FileMaker Server with different values in HTML form?
Cheers,
Jas
Re: possible to submit two find requests
No it is not possible.
Besides doing this with [FMP-If] tags and Tokens, you can use Javascript. So a couple of ways exist.
All the best.
Garry
