YET ANOTHER SCRIPT PROBLEM
Hello, everyone!!
Ok, I am having yet another script problem, and now that I have written a couple of these, I have a question.
This script is suppose to look at a field that is attached to a value list, and see if a certain box is checked (an item in the value list selected), see if a field is empty, and print a letter to these people. It looks like this:
Go to Record/Request/Page [First]
Loop
If ["(PatternCount(Action List, "Appointment Obtained") > 0) and (IsEmpty(Letters2.2))
Set Field ["Letters2.2","Appt. Thanks""]
Insert Current Date [select, "Letters P Date 2.2"]
Go to Record/Request/Page [Exit after last, Next]
Else
If ["Status(CurrentRecordNumber) = Status(CurrentFoundCount)"]
Exit Loop If [1]
Else
Omit Record
End If
End If
End Loop
Go to Layout ["Pre-Appt Confirmation Letter"]
Page Setup
Enter Preview Mode
Print
Blah, Blah
This script seems to work for the most part, but I have only ONE record in my database that matches the search criteria. When the script is executed, it prints for the record that matches, but also prints for the LAST record in the database. I know this because I changed the sort order around a couple of times, but its always the record that matches and the last record. This last record does not fit the search criteria, and the fields "Letters2.2" and "Letters P Date 2.2" will not be set with the information that would be filled if it had matched the criteria, so I think it is slipping through the loop somehow. But it prints anyways. I think I have something in the wrong place, so if you guys could help, I would much appreciate it.
And now my question: If I put an IF Function in a script, and it looks through the records to find those who match, is it really necessary to have an Omit Record step for the recrods that dont match, or does FM simply ignore those records anyway??
Thats it, thanks for all your guys' help!
Ken
Well, nevermind about the script problem, I think I know what I forgot... I need another Omit Record step here:
Omit Record <---here, right?
Exit Loop If [1]
Else
I tried it, and it seems to work now. But I still have the same question that was posed in the original post
Thanks guys
Ken
