Remote popup calendar problems
I've just created a pop-up calendar in FM6. I created it before I realised there was an almost identical thing called Calendar Snap. Well I like my version better. :(-)
The idea being (you've all seen them before), a date field in an FM database has a small calendar button next to it. press it and it fires up a mini calendar. Scan through the months and click on a date. On clicking; the calendar closes and the selected date (which is now in the clipboard) gets pasted into the date field of the original database.
Ok, i've done the hard part and created the calendar.
I can call the calendar by pressing the button, which selects the appropriate external script, but once it has been called, it seems to continue running through the original 'calling script' in parallel and jumps back to the calling database's window and (ie pasting nothing) with the calendar window in the background.
I've tried pause/resume script both in the calling script and the pop-up calendar, but no solution seems to work correctly.
Can anyone help.
(created on a Mac using Developer 6, basic mock-up files attached in zip formt)
Many Thanks
Gary Tamblyn.
calendarproblem.zip
Hi Stuart,
Wow, I thought you solved the problem there for a second, and I guess you had from what I asked. I should have mentioned I would like the script within the calendar to be independent, so anyone can add this calendar to their solution, without having to customise a return script in the pop-up calendar.
The version written here,
http://www.briandunning.com/files/calsnap.sit
seems to work without a return script. (The way I can tell is by changing the name of the calling database doesn't cause an error). I don't know how he does it though ;-)
Thanks for your help though.
I had a quick look at your calendar software, and it looks pretty good. I like all the Aqua graphics. It's a real shame Filemaker doesn't make use of the Aqua interface natively for drop-down menus etc..
just a note, I noticed the screen shot for your calendar has the 4th and 11th transposed, by the way.
How fantastically embarrassing. The 11s out of alignment too so I must have made a cut and paste error at some point. Until now it was just a small part of the main calendar (which you can see a preview of if you click on the picture).
Don't have FMP on the system that i'm currently on so can't view file until tomorrow, can make a guess at a script that will work for what you want though.
PART 1
File = CallingFile.fp5
Field = Entry_Field (date)
Button = Perform Script [Get_Date]
Get_Date Script =
Perform Script,Pause [External[Calendar.fp5 Calendar_Display]]
Go To Field [Entry_Field] Select/Perform
Paste
PART 2
File = Calendar.fp5
Layout = Entry_Layout
Field = Date_Field (date)
Button = Perform Script,Exit Script [Copy_Date]
Calendar_Display Script =
Allow User Abort [off]
Go To Layout [Entry_Layout]
Toggle status Area [Hide,Lock]
Toggle window [Zoom]
Set Field [status(CurrentDate)]
Go To Field [Date_Field] Select/Perform
Loop
Pause [indefinitely]
End Loop
Copy_Date Script =
Exit Record/Request
Copy
Toggle Window [Hide]
Hope this does the job
"How fantastically embarrassing."
I wouldn't worry about it, nobody will notice. ;-)
Thanks for the help with the script, I'll try it out this evening.
Best Regards
Gaz.
Excellent !!!
Thanks Stuart,
I don't think I noticed the 'Pause script' option on my version at home. but it works excellently ;-)
Good luck with your Calendar project.
Kind Regards
Gary Tamblyn.
