November 15, 200421 yr Hi I'm having a problem with an inline (this is the first time I've used them). I have the following link; FMPro?-db=databasename.fp5&-format=formatfile.htm&-lay=layoutname&-error=errorpage.htm&-view The inline on the result page is: [FMP-InlineAction: -db=databasename.fp5, -lay=layoutname, -max=10, -format=formatfile.htm, rep_notify="{ClientUserName}",searchstatus="Yes", -find] It displays the first 10 results ok but when I click on [FMP-linknext] button it doesn't display the next 10 records. Can someone please tell me what I'm doing wrong? ta
November 15, 200421 yr For an InlineAction you do not need the "-format" tag. What does the "rendered" [FMP-LinkNext] look like in the Browser? My guess is that it is attempting to display the "outer" result. All the best. Garry
November 16, 200421 yr Author Hi Garry When I click on the link to get me to the inline the link result is; FMPro?-db=media.fp5&-format=mediaactiveresults.htm&-lay=detail&rep=bob&aemediastatus=Requested%20by%20A%2fE&-max=5&-find= The link on the button for the next set of records is; FMPro?-db=media.fp5&-format=mediaactiveresults.htm&-lay=detail&rep=bob&aemediastatus=Requested%20by%20A%2fE&-max=5&-skip=5&-find= The link result at the bottom of the inline on the next results page is FMPro?-db=media.fp5&-format=mediaactiveresults.htm&-lay=detail&rep=bob&aemediastatus=Requested%20by%20A%2fE&-max=5&-find= However, it is still displaying the original records Cheers Howard
