The Dark Lines Between Layout Parts
Does anybody know how to eliminate the dark line that appears where the header and the body meet and where the body and the footer meet when in the list view?
If you don't actually need the header or footer, you can use the blank layout format. With that, there are no dividing lines in List View.
Actually I think I do need the header & footer!
I frequently use this setup (in the BROWSE mode) to display a listing of all records or filtered records in the table. In the header section I place the column labels. They remain fixed as the user scrolls the list. In the footer section I place buttons that do predefined searches & general navigation. In the body I place the fields and a button to drill into the details (another layout - form style.) I like the way this looks and works other than the dark line.
It seems like in v6 the line only appeared at the seam between the body and the footer whereas in v7 it seems to be showing at the header/body seam and the body/footer seam.
It's really just a cosmetic complaint but I'd like the look of a single rather than sectioned background in the list view.
