November 23, 200421 yr I have a small db that holds all my movies. To make life simple I made a small script that puts the url together for a search on imdb.com. FM submits a valid url to Safari, but in the address bar appears // after the domain. Like this: http://www.google.com[color:"red"]//[/color] search?q=aardman+classics&ie=UTF-8&oe=UTF-8 Is there a bug in the Open url script step? Or do I have to look elsewhere for a fix. Running 10.3.6, FM 7.03 and Safari 1.2.4 TIA
November 24, 200421 yr This has been confirmed as a bug by FileMaker, FileMaker Pro adds a slash to the URL when sending it to Safari. Other browsers are not affected AFAIK.
November 24, 200421 yr Author Thanks for your reply. Unfortunately Firefox and Opera are affected too. While waiting for a fix I'll give AppleScript a go.
November 30, 200421 yr Just found this thread after I posted the same question. One workaround is to use an extra slash and asterix in the calculated URL. In my example: "http://www.google.com" & "[color:"red"]/*/search?hl=en&lr=&q=" & GoogleMe & "&btnG=Google+Search", and the resulting "good" page has an URL of: http://www.google.com//*/search?hl=en&lr=&q=prd-13&btnG=Google+Search. It works but it looks strange.
November 30, 200421 yr NOTE: this is in response to zincb I posted this in another area, so I figured I post it here too. Here's an interesting tidbit. If you use a back slash, "", in front of the "search" word, instead of "/", it works right. So, make your calc look like this: "http://www.google.comsearch?hl=en&q=" & googleMe & "&btnG=Google+Search" HTH Adam
