Referral System NEED HELP!
Ok, I have a referral system set up on Filemaker, but I need help with automating part of it. Each person gets a serial number when placed into the database. This is the referral number. Here is my setup:
Date Ordered: (Date)
First Name: (Name)
Last Name: (Name)
# of Referrals: (sum # of people this person has referred)
Referred by: (the user's ID# whom referred this person)
User ID #: (this person's unique ID#)
Users Referred: (User ID #'s this person has referred)
Each person will get a database filled out with this information. I need help automating the User ID's. Example:
1st DATA ENTRY
Date Ordered: 1/13/05
First Name: Joe
Last Name: Shmoe
# of Referrals: 0
Referred by: None
User ID#: 001
Users Referred: None
2nd DATA ENTRY
Date Ordered: 1/15/05
First Name: John
Last Name: Doe
# of Referrals: 0
Referred by: 001 <<--- I input this number
User ID#: 002
This is what I want to be updated automatically on entry #1
First Name: Joe
Last Name: Shmoe
# of Referrals: 1
Referred by: None
User ID#: 001
Users Referred: 002
The bold is what I want to be automatically updated. Any help will be greatly appreciated!
I could really use the help! Anybody have an idea?
You don't need to duplicate information that's already in the system.
Create a relationship (to the same table) using
User ID # = Referred by
as the match criteria.
Instead of Users Referred, use a portal to show all the people that this user has referred.
Make # of Referrals a calculation = Count ( RelationshipName::User ID # )
Great! That helps a lot! Howeveer, I still want to see which User ID #'s a person referred. So I need the Users Referred field filled in automatically with all the user ID's they have referred. How do I do that? (using the same setup as described in first post)
You will see that in the portal.
J. Doe was referred by J. Shmoe. That is a single item of information. It is not necessary to record the same item twice: once as information about J. Doe, and a second time as information about J. Shmoe.
You have a relationship that connects J. Shmoe's record to all the records of the people that J. Shmoe has referred. And in the portal based on this relationship you will see all the people that J. Shmoe has referred.
I'm new to Filemaker, as you can probably tell, could you explain this portal thing? How can I see all the referrals of J. Shmoe at once? Also, is it possible to make an online form that updates my filemaker form? I want users to enter this data:
First Name
Last Name
Email
Referred by
Address
City
State
Country
Date and Time: (timestamp automatic)
How do I set this up on an online form (using Dreamweaver to build pages). My server has PHP and MySQL if that helps. Thanks!
See this little demo.
Regarding online forms etc., I suggest you make a separate post in the Online section - I know nothing about it.
pyramide.zip
Alright, everything is working so far. Now I added one more column and I need to try and get it to work with everything again, so I need some help. I added a Paid Field: Yes or No. This is information I put in. Now, I only want the # of refferals # to only update if a person has paid. I also want to show all users that are referred, regardless if they payed or not. How do I do this? Currently for the # of referrals, I have this calculation: Count ( Referred by::User ID # ). How can I connect the yes and no of the pay system to help reflect this number? thanks! You guys are great!
still need help here...anyone?
There are several options. I believe this would be the simplest.
pyramide.zip
