Problem with execution of location.href...........
I am using the javascript properties, history.go and location.href in the following code.
The history.go works fine, the location.href partially works. It sends the user back to the confirm_events.xsl page but does not execute the rest of the string. Any help will be much appreciated.......Ray
<xsl:attribute name="onload">
<xsl:choose>
<xsl:when test="$current-action = 'new'">history.go(-1)</xsl:when>
<xsl:otherwise>
location.href = &apos;confirm_events.xsl?-db=Web_TA_Pre_Reg_DB&amp;-lay=Registration Evaluation Form-2&amp;-error=confirm_events.xsl&amp;-token=<xsl:value-of
select="$request-query/fmq:query/fmq:parameter[@name = '-token']"
/>&amp;-token.1=<xsl:value-of
select="$request-query/fmq:query/fmq:parameter[@name = '-token.1']"
/>&amp;-token.2=<xsl:value-of
select="$request-query/fmq:query/fmq:parameter[@name = '-token.2']"
/>&amp;-token.3=<xsl:value-of
select="$request-query/fmq:query/fmq:parameter[@name = '-token.3']"
/>&amp;ParticipantIDQ=<xsl:value-of
/>&amp;-sortfield.1=EventDate&amp;-max=40&amp;-find&apos;;
</xsl:otherwise>
</xsl:choose>
</xsl:attribute>
I see two things:
- replace the spaces in your layout parameter with %20
- all tokens must be named now: -token.something . The very first is not.
Another question:
Why do you use JavaScript for that? What happens if the client has not turned on JavaScript in his browser?
You could also use server-side redirects. Look at my example in this thread: http://www.fmforums.com/threads/showflat.php?Cat=0&Number=151616&an=0&page=1#151616
HI Martin, I will give both your suggestions a whirl when I return to work tomorrow, many thanks........... Ray
Hi Martin, I have a rather captive audience and provide user support for those having problems using our database online. Javascript has not been a problem to date.
I had posted this same question to a Javascript forum and received a response (via an informative link) that resolved the problem. I used an unescaped " instead of the invalid HTML entity reference "&apos;" and it worked fine.
Thanks again for your input.........roadrunner(Ray)
